[GRASSLIST:4749] Re: best command for operation?
Eric G. Miller
egm2 at jps.net
Tue Oct 15 21:24:34 EDT 2002
On Tue, Oct 15, 2002 at 11:07:59AM -0700, Jeff D. Hamann wrote:
> I've got a few (about five say) raster files that I need to combine into a
> fuels model layer, such that the cells will contain categories (0-14,
> etc)...
> I have a raster file for slope, aspect, elev, veg type, etc....
> I need to perform calcs like:
> if( elev > 3000 && slope > 40 pct && aspect >= 90 && aspect < 270 )
> fuel_model = high alt fuel model
> if( elev <= 3000 && slope > 40 pct && aspect >= 90 && aspect < 270 )
> fuel_model = low alt fuel model
> I'm using GRASSpre4 on cygwin, win2k, and can write C code just fine. Should
> be using r.combine, r.mapcalc, or write some C code (using a lib that I can
> read/write GRASS files independently of GRASS) to perform this task.
I'd try to solve it in the following order:
1. r.mapcalc
2. shell scripting
3. C programming
>From what you've posted, it looks like r.mapcalc can handle it.
static const char signature[] =
"Copyright (c) 2002 Eric G. Miller <egm2 at jps.net>";
