[GRASSLIST:4769] Re: batch jobs
M.Wegmann
m.wegmann at web.de
Fri Oct 18 03:14:56 EDT 2002
Hello,
first thanks a lot for your help, I managed to write my first bash script and it's working.....nearly ;-)
could it be, that I can't grab a file which is an output of a GRASS command?
eg (temp and $temp):
r.mapcalc "temp=int(raster*1000000)"
r.statistics base=killarney cover=$temp method=....
here it seems that it can't read the $temp file. error message is: "no cover map found". what would be a solution for that?
and another thing, I want to do a loop for all images starting with the letter b,d and t.
eg
for x in "[a,d,t]*"
do
r.mapcalc "temp=int($x*1000000)"
done
but that doesn't work. something wrong in the way I wrote it?
thanks for your help, Martin
