[GRASSLIST:4778] Re: batch jobs
Glynn Clements
glynn.clements at virgin.net
Fri Oct 18 04:26:15 EDT 2002
M.Wegmann wrote:
> first thanks a lot for your help, I managed to write my first bash
> script and it's working.....nearly ;-)
> could it be, that I can't grab a file which is an output of a GRASS
> command?
> eg (temp and $temp):
> r.mapcalc "temp=int(raster*1000000)"
> r.statistics base=killarney cover=$temp method=....
> here it seems that it can't read the $temp file. error message is: "no
> cover map found". what would be a solution for that?
Omit the dollar sign. "$temp" refers to the contents of the shell
variable called "temp"; but there is no such variable, so you are
effectively running:
r.statistics base=killarney cover= method=....
I.e. the value of the "cover=" parameter is empty.
You only use the dollar sign when you want to use the value of a
variable (e.g. from a "for" loop, a "read" statement etc).
> and another thing, I want to do a loop for all images starting with
> the letter b,d and t.
> eg
> for x in "[a,d,t]*"
> do
> r.mapcalc "temp=int($x*1000000)"
> done
> but that doesn't work. something wrong in the way I wrote it?
Omit the quotes, and the commas, i.e.
for x in [adt]*
Filename "globbing" (replacing a pattern with all filenames which
match that pattern) isn't performed within quotes. However, variable
expansion (i.e. replacing $x with the value of x) is performed within
double quotes, but not within single quotes.
Glynn Clements <glynn.clements at virgin.net>
