[GRASSLIST:4791] Re: Exporting raster map
Glynn Clements
glynn.clements at virgin.net
Sun Oct 20 19:14:02 EDT 2002
Alexandra Zamparas wrote:
> Thank you for your reply. In trying to use p.map.new I got the
> message: ERROR: PAINTER not set. Is there some configuration that I
> have to do first? I gave the input name and the scale.
You need to select a "device" with p.select before any other p.*
commands.
However, p.map.new is probably the wrong tool here; r.out.ppm is
likely to be a better choice for generating a PPM file. PPM can be
converted to a wide range of formats using the pbmplus/netpbm tools.
Glynn Clements <glynn.clements at virgin.net>
