[GRASSLIST:4805] Alternate ODBCs in SuSE 8.1
John Dougherty
jwd at softcom.net
Wed Oct 23 01:25:24 EDT 2002
I just recompiled GRASS 5.0 for SuSE 8.1. Most of the process proved
reasonably straightforward. However, the ODB library(ies) proved a little
problematic. There are obdc libs installed with main installation, however
GRASS seems to be in need of the unixODBC, or at least that seemed to be what
solved the problem. SuSE however, alerts repeatedly that the unixODBC and
the libodbc already installed can cause conflicts and may destablize the
system. Are there any recommendations about handling this from the GRASS
team?
JWDougherty
