[GRASSLIST:4810] Re: Latitude-Longitude/UTM conversion
Glynn Clements glynn.clements at virgin.net
Wed Oct 23 08:17:55 EDT 2002
andres javier garcia garcia wrote:
> Please. Which comand should I use to convert Lat-Lon Data to UTM?
r.proj, v.proj, or s.proj, for raster maps, vector maps, and site maps
respectively. In each case, you need to import the data into a lat-lon
location, then run the commands from within a suitable UTM location.
Glynn Clements <glynn.clements at virgin.net>
