[GRASSLIST:4825] Re: NVIZ libpq.so error
Markus Neteler neteler at itc.it
Fri Oct 25 03:41:41 EDT 2002
On Thu, Oct 24, 2002 at 06:33:39PM +0200, andrea mamusa wrote:
> Hi,
> I have a problem when i run NVIZ in GRASS 5.0.0pre5 rpm binaries on a
> redhat 7.3 linux os (the same problem after upgrade to redhat 8.0):
> /opt/grass5/etc/nviz2.2/NVWISH2.2: error while loading shared
> libraries: libpq.so: cannot load shared object file: No such file or
> directory
> postgresql server and postgresql libs 7.2.2-1 are installed.
Please check if there is a link in /usr/lib
libpq.so.2.1 -> libpq.so
(or similar version number or path). If not, add it and NVIZ
should work.
Good luck,
 Markus
