[GRASSLIST:4839] Re: odbc problem
John Dougherty jwd at softcom.net
Sat Oct 26 00:47:25 EDT 2002
-----BEGIN PGP SIGNED MESSAGE-----
On Thursday 24 October 2002 07:21, Miha STAUT wrote:
> Hi,
> I ran into a problem while trying to connect to Grass5.0.0 my database of
> communalities in Slovenia that I have in PosgreSQL. The problem Grass is
> complaining about looks like this:
> GRASS:~ > db.connect driver=odbc database=obc user=root
> driver:odbc
> database:commun
> location:(null)
> user:root
> password:(null)
> key:(null)
> GRASS:~ > db.databases
> /usr/local/grass5/driver/db/odbc: error while loading shared libraries:
> libodbc.so.1: cannot open shared object file: No such file or directory
> dbmi: Protocol error
> Can't run driver (null)
You don't say which release you use, but generally the releases do not install
OBDC unless you tell them to.  You may run into some conflicts if you also
have libodbc installed - I just posted to the list about this myself.
John
-----BEGIN PGP SIGNATURE-----
Version: 2.6.3in
Charset: noconv
iQEVAwUBPboeZ3lbleuWrPajAQGP7gf8C9J+cq4Y1UfORdJUpRG9J2vl7CA9oQ4S
rzjkYArlnV188hVEki4DeLJhsHFZK/7K7ZjioX3DyHXTwAgqQnpfHkDCdR97T76C
VknDf/BFxnKioNAogaQ9BArOITJqXe4PAOJPK9dgk8gzT6/ccasLQyhBabZxSTuY
hEChcSldUKkga06pAozwFDpiCVVmARJTBhWdbjQ9K9itNvd/a42Gb9bV5nR+drrU
FMLghOdRbX5H4WogRfayDHEhAYR2VT1bvCjE71Yhv/OJWU/VGeIdGXyBvXBJykc4
tENeMH/mHiQwTJzGFbkuK/CTx5Xp948AKC5Ypm98KQzOM9ibosgtTw==
=b+hJ
-----END PGP SIGNATURE-----
