[GRASSLIST:4867] Re: copying regions between systems
Xueming Wu xwu at cse.unl.edu
Thu Oct 31 18:51:48 EST 2002
What I usually do is following:
1. create a new mapset in new location.
2. copy the subdirectories from the original mapset, such as cats,
   dig and so on.
3. run some support command, such as r.support, v.support and so on.
Hope this may be help.
Regards,
Xueming
On Thu, 31 Oct 2002 cbsled at ncia.net wrote:
> Can I simply tar up the region's dir in the database and copy it to another machine?
> Or is there more to it than that, and if so, what?
> TIA
> Carl Brown cbsled at ncia.net
