[GRASSLIST:4421] one column wide filtering
    Thomas Dewez
    Thomas.Dewez at brunel.ac.uk
    Thu Sep  5 08:39:41 EDT 2002
Dear all,
I would like to pass a one-column-wide and 51-rows-high maximum filter on
a DEM. I found the maximum method in the r.neighbors command and the
custom-size filter in the r.mfilter. How is it possible to obtain combine
them?
Ultimately, I want to obtain an elevation profile of the ridge line of a
fault bounded mountain front. I was going to pick up the E-W trending
mountain ridge with the one-column-wide 51-pix-long maximum filter, then
use the resulting target pixels to produce a vector line and extract the
elevations within a buffer zone of the ridge line.
That's the result of my convoluted thoughts at the moment. Perhaps there
is an easier way to proceed, I am open to suggestions.
Cheers,
Thomas
