[GRASSLIST:4458] d.mon -> X Error ->monitor fails to open
    John Gillette
    JGillette at rfmd.com
    Wed Sep 11 11:00:24 EDT 2002
Grass5.0.0 on "dist.sparc-sun-solaris2.7" just compiled.
Starting grass from same place as pre3 version (i.e.
same .grassrc5 files, data base etc.).
TCLTKGRASS 3.2(2001) pops right up.
Go to start monitor and I get the following:
 found 5 visuals of type TrueColor
 searching for highest bit depth
 selected 24 bit depth
 X Error of failed request:  BadMatch (invalid parameter attributes)
   Major opcode of failed request:  1 (X_CreateWindow)
   Serial number of failed request:  8
   Current serial number in output stream:  20
 No socket to connect to for monitor <x0>.
 Problem selecting x0. Will try once more
I am enclosing a print out of xdpyinfo for reference.
I have a SUN ultra 10. I don't know how to tell
what video card I have.
I need help again, please.
This is a change from pre3 which never had a problem
opening a monitor.  I did have problems with the colors
(or lack there of) but not the monitor.
John
name of display:    :0.0
version number:    11.0
vendor string:    Sun Microsystems, Inc.
vendor release number:    3610
maximum request size:  262140 bytes
motion buffer size:  256
bitmap unit, bit order, padding:    32, MSBFirst, 32
image byte order:    MSBFirst
number of supported pixmap formats:    3
    depth 1, bits_per_pixel 1, scanline_pad 32
    depth 8, bits_per_pixel 8, scanline_pad 32
    depth 24, bits_per_pixel 32, scanline_pad 32
keycode range:    minimum 8, maximum 132
focus:  window 0x5c0000d, revert to PointerRoot
number of extensions:    27
    AccessX
    Adobe-DPS-Extension
    DOUBLE-BUFFER
    DPMS
    DPSExtension
    Extended-Visual-Information
    LBX
    MIT-SCREEN-SAVER
    MIT-SHM
    MIT-SUNDRY-NONSTANDARD
    Multi-Buffering
    RECORD
    SECURITY
    SHAPE
    SUN_ALLPLANES
    SUN_DGA
    SUN_OVL
    SUN_SME
    SYNC
    SolarisIA
    TOG-CUP
    XC-APPGROUP
    XC-MISC
    XIE
    XInputDeviceEvents
    XInputExtension
    XTEST
default screen number:    0
number of screens:    1
screen #0:
  dimensions:    1280x1024 pixels (361x288 millimeters)
  resolution:    90x90 dots per inch
  depths (3):    1, 8, 24
  root window id:    0x37
  depth of root window:    8 planes
  number of colormaps:    minimum 1, maximum 5
  default colormap:    0x34
  default number of colormap cells:    256
  preallocated pixels:    black 1, white 0
  options:    backing-store YES, save-unders YES
  largest cursor:    64x64
  current input event mask:    0x78003f
    KeyPressMask             KeyReleaseMask           ButtonPressMask
    ButtonReleaseMask        EnterWindowMask          LeaveWindowMask
    SubstructureNotifyMask   SubstructureRedirectMask FocusChangeMask
    PropertyChangeMask
  number of visuals:    16
  default visual id:  0x20
  visual:
    visual id:    0x20
    class:    PseudoColor
    depth:    8 planes
    available colormap entries:    256
    red, green, blue masks:    0x0, 0x0, 0x0
    significant bits in color specification:    8 bits
  visual:
    visual id:    0x21
    class:    PseudoColor
    depth:    8 planes
  visual:
    visual id:    0x22
    class:    StaticColor
    depth:    8 planes
    red, green, blue masks:    0x7, 0x38, 0xc0
  visual:
    visual id:    0x23
    class:    StaticGray
    depth:    8 planes
  visual:
    visual id:    0x24
    class:    GrayScale
    depth:    8 planes
  visual:
    visual id:    0x25
    class:    TrueColor
    depth:    8 planes
    available colormap entries:    8 per subfield
  visual:
    visual id:    0x26
    class:    DirectColor
    depth:    8 planes
  visual:
    visual id:    0x27
    class:    StaticGray
    depth:    8 planes
  visual:
    visual id:    0x2e
    class:    PseudoColor
    depth:    8 planes
  visual:
    visual id:    0x2f
    class:    PseudoColor
    depth:    8 planes
    available colormap entries:    255
  visual:
    visual id:    0x28
    class:    TrueColor
    depth:    24 planes
    available colormap entries:    256 per subfield
    red, green, blue masks:    0xff, 0xff00, 0xff0000
  visual:
    visual id:    0x29
    class:    TrueColor
    depth:    24 planes
  visual:
    visual id:    0x2a
    class:    DirectColor
    depth:    24 planes
  visual:
    visual id:    0x2b
    class:    DirectColor
    depth:    24 planes
  visual:
    visual id:    0x2c
    class:    TrueColor
    depth:    24 planes
  visual:
    visual id:    0x2d
    class:    TrueColor
    depth:    24 planes
