[GRASSLIST:4520] results of r.statistics
Alexander Fritz
Alex_Fritz at gmx.net
Tue Sep 17 11:01:50 EDT 2002
Hello everybody,
I use r.statistics with the sum method. I'm using GRASS 5.0.0 on
Windows2000/Gygwin. When I do a calculation in GRASS I get different results
as in ARCView using the "summarize Zones" command in the Analyses menu. I
have seen in the mailing list that a similar problem has occured some time
ago. I use integer values. Has anybody a suggestion how I can do this
calculation in a different way?
Greetings Alex
