[GRASSLIST:4541] Re: Raster to vect. A simple question?
Camilo Castiblanco
camilocast at tutopia.com
Fri Sep 20 01:07:57 EDT 2002
Dear andres
You can to obtain a contour map (vector map) with the command r.contour.
With the command v.out.dxf you get the dxf map
----- Original Message -----
From: "andres javier garcia garcia" <andresjavier.garcia at wanadoo.es>
To: "GRASS LIST" <GRASSLIST at baylor.edu>
Sent: Thursday, September 19, 2002 9:38 AM
Subject: [GRASSLIST:4535] Raster to vect. A simple question?
> I need to obtain a dxf file from a raster map. This map is just 1 for a
> watershed and null for the rest.
> How could I do this?
> I've tried and I can't see the way.
> thanks
> Javier
