Hi; I've exported a dxf map from an ascii vector map. But it seems that there is a problem with the exporting processs. (gras5.0.0pre5). When I try to open the dxf file with another program (Autocad or other) there is an error an the dxf can't be read. Is there a known error in this program (v.out.dxf)?
