[GRASSLIST:4557] Re: [winGRASS] A million and a half questions.
Mike Thomas
mthomas at gil.com.au
Mon Sep 23 05:12:16 EDT 2002
Hi Dave.
Welcome to the world of GIS and Grass. It can only get better for you from
here although the road may be painful at times!
The wingrass mailing list probably isn't the best place to ask most of these
questions, as it is relatively small and specialised. Accordingly I have
cc'ed your email to the main Grass list which has many more subscribers and
where you may have a better chance of getting the kind of information you
need.
It seems to me that you particularly need to find a surveyor or cartographer
using Grass in the United States.
The Windows Grass release is experimental, but is never-the-less
sufficiently solid to be used by at least one professional geographer that I
am aware of.
Cheers
Mike Thomas.
----- Original Message -----
To: <wingrass at grass.itc.it>
Sent: Saturday, September 21, 2002 11:14 AM
Subject: [winGRASS] A million and a half questions.
> Hello everyone; I'm new to the list, so let me start with an introduction:
> The name's Dave Graham. I'm an instrumentman for a small civil
engineering/land surveying company in Bloomington Indiana, and I'm just
starting to research GIS -- so naturally, I've got a million and a half
questions.
> For starters, I'm wondering if there are any other surveyors on this list
using GRASS or WinGRASS who might give me testimonials -- or surveyors in
states with a public land survey system (Townships and Sections) that might
give me tips.
> I'm fairly familiar with Linux/Unix -- though my boss and coworkers
aren't, which makes WinGRASS a reasonable compromise. (Though I haven't
ruled out the possibility of building a Linux box for the office network,
which is currently running Win2k.)
> Regardless, many of my questions could probably be answered by anyone on
this list, so here's an example:
> I'm considering creating a GIS in which each Section is a plane; land
surveys in that Section will accordingly have x,y coordinates within that
plane. This would, of course, create a gigantic soccer-ball of
Section-Planes. Say then, that I aquired a huge area of data that spanned
multiple sections in a different projection, like UTM or State Plane -- am I
going to be able to use the two together without alot of hairy conversions?
> Also, how would something like this be set up in GRASS? Would I have to
create a separate location for each Section, giving it an x,y projection --
or would I be able to get by making a location for each Township, with each
Section as a mapset?
> The questions only get worse from here; any help would be greatly
appreciated.
> - dave graham
> Get your free email from www.linuxmail.org
> Powered by Outblaze
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
