[GRASSLIST:4592] Re: vector road map from tiff image
    Glynn Clements
    glynn.clements at virgin.net
    Fri Sep 27 07:34:23 EDT 2002
Philip Mark Donaghy wrote:
> Can grass read a tiff image
Yes, with r.in.tiff.
> and detect lines and polygons to create a
> vector basemap of lines and polygons?
Yes, with r.poly (polygons) and r.line (lines).
> To complicate things the image has
> text and icon labels. The number of unique colors in the image is 1687.
> It seems obvious to me that I will have to modify/simplify the image to
> get good results. But I don't know to what degree.
You will probably need to remove the labels prior to analysis. If the
number of colours reflects the fact that areas or lines use a range of
colours, you would need to fix that also.
> Can anyone with some ideas tell me which grass module does this type of
> raster to vector transform? I can provide a sample image if necessary.
r.in.tiff, r.poly, r.line, and r.thin and v.support are likely to be
relevant. Some of the other modules might be useful for pre-processing
the data.
Glynn Clements <glynn.clements at virgin.net>
