[GRASSLIST:4595] Use of -i option in m.in.e00
Bruce Saunders
b.saunders at mindspring.com
Sat Sep 28 01:08:41 EDT 2002
Hello,
I have imported a number of Arc/Info vector E00 coverages into GRASS 5.0,
mostly without problems. However, I am not certain if I should or should
not use the -i option to change the indexing term assigned to polygon
and line objects.
The E00 format documentation (v7) suggests some feature attributes are
linked by "feature id" and others by "feature #" in the E00 file. I
could not unravel the ball of string which links various EOO data
together, and I could not find much detail in the m.in.e00 manual page
or previous posts to this list.
Can anyone briefly explain how GRASS object indexing works, how m.in.e00
converts Arc/Info indexing to GRASS indexing, and when the -i option
matters?
Thanks for any pointers,
- Bruce Saunders <b.saunders at mindspring.com>
