[GRASSLIST:4598] Re: aggregate a higher resolution to a lower resolution
Gordon Keith
gordon.keith at csiro.au
Sun Sep 29 18:44:21 EDT 2002
On Fri, 27 Sep 2002 16:51, Ulrich Leopold wrote:
> which version has the s.cellstats? 5.1? I have currently 5.0.0pre5.
> The problem about s.windavg is I will not get the variance. But maybe
> it's a good idea to convert to an ascii file and do the aggregation
> outside grass with awk etc..
---------- Forwarded Message ----------
Subject: [GRASSLIST:4553] s.cellstats implementation
Date: Sat, 21 Sep 2002 21:10:11 -0700
To: GRASSLIST <GRASSLIST at baylor.edu>
Cc: GRASS5-dev <grass5 at grass.itc.it>
I've posted an implementation of "s.cellstats", a program to calculate
univariate statistics for sites on a per cell basis. It is adapted
from s.univar and the result of some discussions with Gordon Keith.
If folks would like to give it a whirl:
http://pweb.jps.net/~egm2/grass/s.cellstats/s.cellstats.html
I will be adding it to the GRASS source tree before too long, unless
there is some objection...
s.cellstats (and s.univar) does 12 statistics, including coefficent of
variance.
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
In theory there is no difference between theory and practice.
In practice there is.
