[GRASSLIST:5948] Re: r.in.tiff problem
Eric G. Miller
egm2 at jps.net
Wed Apr 2 11:06:12 EST 2003
On Wed, Apr 02, 2003 at 10:46:35AM -0500, Michael Ash wrote:
> I am having some trouble importing scanned maps with
> r.in.tiff.
> The trouble occurs with GRASS 5pre3 for X on
> WindowsXP/Cygwin but not with GRASS 5.0.0 on Linux. In the
> 5pre3 installation, I get the following error message:
> WARNING: G_set_window(): Illegal latitude for North
> ERROR: couldn't set cellhd.
> Is this a Windows problem or a pre3 problem? What do you
> recommend?
A later version of r.in.tiff checks for the projection... An
unreferenced TIFF will have a "region" of 0..width by 0..-height pixels
and a cell size of 1. But, 90 pixels isn't very many...
Solution: (1) Import unreferenced images into an XY location.
(2) Newer r.in.tiff will set the projection to XY for the image if it
doesn't have a TFW (I think, maybe this was not a good idea since most
of the projection info is per LOCATION not data set).
(1) is probably the preferred solution.
echo ">gra.fcw at 2ztr< eryyvZ .T pveR" | rot13 | reverse
