[GRASSLIST:5968] Re: HELP! v.in.shp and database
    cheg01 at attbi.com
    cheg01 at attbi.com
    Sat Apr  5 15:45:24 EST 2003
Try "pg.in.dbf" instead of "v.in.shape.pg"
----- Original Message -----
From: "Schuyler Fishman" <schuylerfish at earthlink.net>
To: <grassLIST at baylor.edu>
Sent: Saturday, April 05, 2003 11:22 AM
Subject: [GRASSLIST:5967] HELP! v.in.shp and database
> The manual says there is a command v.in.shape.pg that build the entire
> database file from the esri shape file. does anyone know why when I
> type this it says command not found?
> Also - if this command does not exists - how do I go about creating the
> attribute database for the grass vector file once I have imported it
> with v.in.shape.
> Is there a GRASS database tutorial?
> THANKS
> Schuyler Fishman
> Schuylerfish at earthlink.net
> www.mindlikesky.com
