[GRASSLIST:6022] Re: [Q] Long path for DATABASE
Glynn Clements
glynn.clements at virgin.net
Fri Apr 11 11:20:57 EDT 2003
Shin, Daehyok wrote:
> Maybe a trivial question, but I can't find the answer
> from the web site.
> How can I put in a very long path to DATABASE
> in the first setup window of GRASS?
You can't; the interactive startup imposes a 50-character limit upon
the database directory.
However, you can avoid that limit by using the non-interactive
startup, i.e.
grass5 /path/to/database/location/mapset
Glynn Clements <glynn.clements at virgin.net>
