[GRASSLIST:6053] i.pca  calls r.in.gdaln ??
    John Chesnut
    jchesnut at slonet.org
    Mon Apr 14 21:38:20 EDT 2003
System: 	Mac OSX 10.2.4
Grass Version:	 OpenOSX binary 5.0  with OpenOSX update 0.1
Problem:
When I attempt to use i.pca under either  xterm or the tcltk
interface Grass parses the function as
r.in.gdal, and exits with an error.
for example the function call:
i.pca -help
Yields the following text which clearly refers to r.in.gdal::
<<snip>>
Description:
  Import GDAL supported raster file into a binary raster map layer.
Usage:
  i.pca [-oe] input=name [band=value] output=name [target=name]
    [title="phrase"] [location=name]
Flags:
   -o   Override projection (use locations projection)
    <<snip>>
Is this a compile problem with the OpenOSX binary, or local to my
install, or is a universal bug ?
How do i fix i.pca ?
-john chesnut
