[GRASSLIST:6080] Re: Getting started with postgresql and GRASS
douggorley at shaw.ca
Thu Apr 17 18:17:21 EDT 2003
> I have both postgresql and GRASS working on my linux box.
> I can use psql to create, query, delete, etc. postgresql databases.
> But so far I cannot get GRASS to talk to postgresql.
> I tried the following according to the first-steps tutorial
> http://freegis.org/cgi-
> bin/viewcvs.cgi/~checkout~/grass/src.garden/grass.postgresql/tutorial/index.html
> GRASS:~ > g.select.pg -l
> g.select.pg: error while loading shared libraries: libpq.so:
> cannot load shared object file: No such file or directory
> I then tried without success:
> export POSTGRES_LIB=/usr/local/pgsql/lib
> I will be grateful for guidance.
> Here is some info about GRASS and postgresql on my system:
> GRASS:~ > g.version
> GRASS 5.0.0 (August 2002)
> GRASS:~ > locate libpq.so
> /usr/local/pgsql/lib/libpq.so.3
> /usr/local/pgsql/lib/libpq.so.3.0
> GRASS:~ > ps -ax | grep postmaster
> 18820 pts/2 S 0:00 /usr/local/pgsql/bin/postmaster -D
> /usr/local/pgsql/d
Michael,
When you compiled GRASS, was it with the "--with-postgres" option, and did you set the "--with-postgres-libs" and/or "--with-postgres-includes" options?
Doug Gorley | douggorley at shaw.ca
