[GRASSLIST:6095] nviz
    Oggi
    m.wegmann at web.de
    Fri Apr 18 21:56:48 EDT 2003
thanks nviz is working!
only one problem but that seems not to be due to GRASS is that the NVIZ window
can'f be resized and therfore I can not see the bottom of the window.
any idea how I can solve this problem?
nice eastern, cheers Martin
On Thursday 17 April 2003 16:19, Otto Dassau wrote:
> Hi Martin,
> for me this error message for NVIZ appears
> when I tried to use the package from
> http://grass.itc.it/grass5/binary/linux/nviz_postgresql_tk83_i686-pc-linux-
>gnu_.tar.gz
> which was compiled on Redhat with Tcltk 8.3.
> If you use Tcltk 8.4 maybe you should try the
> other package compiled on SuSe 8.1. This hopefully
> works for you ...
> http://grass.itc.it/grass5/binary/linux/nviz_postgresql_tk84_i686-pc-linux-
>gnu_.tar.gz
>   Otto
> > I downloaded the GRASS 5.0.2  binary
> > but when I start NVIZ I can choose raster, vector maps etc. but instead
> > of a display the following error message appears - it looks similar to
> > the error prompt of my previous GRASS version when it didn't support
> > tc/tkl 8.4 as far as I can judge it ;-).
> > BTW the command r.series, r.mapcalc3 etc. all the new one are not found
> > in grass 5.0.2 (>command not found), I tought that I downloaded the old
> > one by mistake but I recognized some changes in the interface and the
> > GRASS info tells me as well that it is 5.0.2.
> > any idea? otherwise I will try the source code .
> > cheers Martin
> > The papers are available at
> > http://www2.gis.uiuc.edu:2280/modviz/
> > Loading Data
> > building color table
> > Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
> > Nv_(panels)
> > toplevel made
> > child killed: segmentation violation
> >     while executing
> > "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
> > /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=00l -name NVIZ
> > >&@stdout"
> >     ("eval" body line 1)
> >     invoked from within
> > "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> > $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
> > >&@stdout" invoked from within
> > "if {$argv == ""} {
> > #no arguments
> > $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
> >     (file "/usr/local/grass5/bin/nviz" line 16)
