[GRASSLIST:6098] Re: 5.0.2 problem
    Glynn Clements
    glynn.clements at virgin.net
    Sat Apr 19 09:00:37 EDT 2003
Oggi wrote:
> > r.series is only available if you compile GRASS from the source code.
> > It isn't built as a result of running "make" (which is why it isn't in
> > the binary packages); you have to compile it separately (or modify
> > src/CMD/lists/GRASS before running "make").
> I installed grass 5.0.2 source code sucessfully (well no error messages at the
> end ;-) ) and read the part "compiling modules not compiled by default" in the
> INSTALL GRASS text, to install r.series.
> how do I compile it seperately? in the INSTALL textit is described that you
> have t type gmake5 in the modules's directory, but in which directory shall
> the module directory be - the one in /usr/local/... or
> the one in my home directory from where i installed GRASS? - either in the
> module directory under /   (only one called module:
> /usr/local/grass5/tcltkgrass/module) nor under ~/  could I find r.series.
It is referring to the directory which contains the module's source
code.
Glynn Clements <glynn.clements at virgin.net>
