[GRASSLIST:6105] RE: NVIZ problem
Nico Hardebol
harj at geo.vu.nl
Tue Apr 22 08:42:23 EDT 2003
Hello,
I was confronted with the same problem, although at first, during
installation of the new grass5.0.2 I received NVIZ-error during compilation,
I finally solved it but could nevertheless not run NVIZ under grass5.0.2
with the same error message.
I recognized comparable problems with other shared libraries libtk.so.0 &
libpq.... for linking grass with psotgresql
somehow the shared libraries were not properly linked during booting,
because when I linked the shared libraries manually by typing:
/sbin/ldconfig
at least the problems with NVIZ were solved.
I'm running the newest Suse linux 8.2 on dell laptop - but afterwards
downgraded the tcl/tk libraries to 8.3 (instead of 8.4)
However I still have porblems with grass.postgresql during configuration -
may message to list will come....
may this help you
-----Oorspronkelijk bericht-----
Van: owner-GRASSLIST at baylor.edu
[mailto:owner-GRASSLIST at baylor.edu]Namens orkun
Verzonden: dinsdag 22 april 2003 12:53
Aan: GRASSLIST at baylor.edu
Onderwerp: [GRASSLIST:6104] NVIZ problem
Hello
I encounter a problem using NVIZ in grass5 and rh 9.
I tried to fix the problem by soft link of libtk.so.0 to
libtk.so. But the problem is not solved.
what do you recommend me ?
Here is the error message:
/usr/local/grass5/etc/nviz2.2/NVWISH2.2: error while loading shared
libraries: libtk.so.0: cannot open shared object file: No such file or
directory
child process exited abnormally
while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=f28elv2 -name
NVIZ >&@stdout"
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass5/bin/nviz" line 16)
thanks inadvance
Ahmet Temiz
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake
Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak
T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte
degildir.
