[GRASSLIST:6110] Re: Problem with d.vect.pg
Michael Ash
mash at econs.umass.edu
Tue Apr 22 16:54:04 EDT 2003
> I use GRASS 5.0.1 and I encountered a problem with
> d.vect.pg It sends the SQL request to the PostGreSQL
> database without problem, it also returns the number of
> rows that it has found in the database, but then it does
> not display anything on the monitor.
> Has anybody encountered this problem? Is there a solution?
I am very glad that you asked this question because I, too,
hope for some clarification on using the GRASS/PostGreSQL
interface from GRASSLIST participants.
As for your problem, is it possible that the column in the
database table referenced either as key=[column] in the
d.vect.pg statement or in the SELECT [column] of the sql
file does not correspond to the vector category values for
the map designated with map=[map] in the d.vect.pg
statement?
My understanding is that the SQL statement should return
exactly one column of numbers that correspond to the the
vector category values for the map designated with map=[map]
in the d.vect.pg statement.
I am attaching a script that I wrote that will
1) import a m.in.e00 file
2) correct dangles (necessary with the test data files)
3) assign a useful connection between categories and names
4) load the vector file into a postgresql database file
5) run a simple query
# Import a .e00 and create a postgresql database table
# Assumes location has been created for North America
# Assumes both postgresql and the GRASS/postgresql connection
# are working and database has been selected
# Script imports a .e00 file from the U.S. Census
# http://www.census.gov/geo/www/cob/bdy_files.html
# http://www.census.gov/geo/www/cob/st2000.html
# Corrects the dangles (in Texas)
# Loads the vector file into a postgresql database for querying
m.in.e00 input=st99_d00.e00 action=vector
g.region.sh vector=st99_d00 nsres=0.1 ewres=0.1
v.support -r map=st99_d00 err=err
v.rm.dangles input=st99_d00 output=st99_d00.corrected
cp ~/grass/usaLL/mash/dig_att/st99_d00 ~/grass/usaLL/mash/dig_att/st99_d00.corrected
cp ~/grass/usaLL/mash/dig_cats/st99_d00.name ~/grass/usaLL/mash/dig_cats/st99_d00.corrected
v.support -r map=st99_d00.corrected
# Create database table st99_d00_bnd (bnd assigned, for "boundary")
# Choose name of key column; I chose "id"
v.to.pg -t tab=st99_d00 type=area map=st99_d00.corrected key=id
g.table.pg
g.column.pg table=st99_d00_bnd
# Select most of Maine
d.vect.pg -f map=st99_d00.corrected tab=st99_d00_bnd key=id where='id=100' color=red
Some requests for clarification:
1. Which file in dig_cats contains the category values for
[map]? Sometimes the first category value appears to be "1"
and sometimes "2". I think that I may be confused about
feature-ID and feature-# , and whether I should use the "-i"
option with m.in.e00. The documentation seems to suggest
that "-i" is more reliable for matching, but I got funny
results (Nevada where California should be, for example)
2. Is there an efficient way to load the categories that
come with a .e00 file (and become separate files in
dig_cats) into one or more database tables? Without loading
the more useful columns, e.g., name, the only possible
selections are on the internal category ID, not very useful
for joining with other data.
