[GRASSLIST:6136] RE: NVIZ problem
Nico Hardebol
harj at geo.vu.nl
Fri Apr 25 06:37:19 EDT 2003
dear Markus,
both suse 8.1 as 8.2 do deliver version 8.4 of tcl.
possibly related to this newest version I met other problems, with which I
was not confronted while installing grass5.0.0 under suse 7.2.
grass.postgresql does not compile ...
./configure --with-postgres-includes=/usr/local/pgsql/include --with-postgre
s-libs=/usr/local/pgsql/lib --with-dbm --with-
gdal=/home/nico/gdal-1.1.8 --with-freetype --with-freetype-includes=/usr/inc
lude/freetype2 --with-freetype-libs=/usr/lib
resulting in:
GRASS is now configured for i686-pc-linux-gnu
Source directory: /home/nico/grass5.0.2
Build directory: /home/nico/grass5.0.2
Installation directory: /usr/local/grass5
C compiler: gcc -g -O2
FORTRAN compiler: g77
NVIZ: yes
X11 support: yes
DBM support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
OpenGL(R) support: yes
ODBC support: yes
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: yes
GLw support: no
NLS support: no
Readline support: no
make 2>&1 | tee compileOutput.log
error.log:
GRASS GIS source code compiled.
Compilation error in module: src/misc/m.kappa (ignored)
Compilation error in module: src/raster/r.in.doq (ignored)
Compilation error in module: src/raster/wildfire (ignored)
Compilation error in module: src.garden/grass.postgresql (ignored)
part of compileOutput.log with the grass.postgresql - errors:
/home/nico/grass5.0.2/src.garden/grass.postgresql/g.column.pg
mkdir OBJ.i686-pc-linux-gnu
make -f OBJ.i686-pc-linux-gnu/make.rules
make[2]: Entering directory
`/home/nico/grass5.0.2/src.garden/grass.postgresql/g.column.pg'
cc -I/home/nico/grass5.0.2/src/include -g -O2 -I/usr/local/pgsql/include -
Wall -DPACKAGE=\""g.column.pg"\" -c main.c -o
OBJ.i686-pc-linux-gnu/main.o
main.c:83:30: missing terminating " character
main.c: In function `main':
main.c:84: error: parse error before "a"
main.c:85: error: stray '\' in program
main.c:85:35: missing terminating " character
main.c:87:37: warning: multi-character character constant
main.c:91:34: missing terminating " character
main.c:96:30: missing terminating " character
main.c:97: error: parse error before "FROM"
main.c:98:37: warning: multi-character character constant
main.c:101:34: missing terminating " character
/usr/include/stdlib.h: At top level:
/home/nico/grass5.0.2/src/include/gis.h:35: warning: `GRASS_copyright'
defined but not used
make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
make[2]: Leaving directory
make[1]: *** [all] Error 2
make[1]: Leaving directory
`/home/nico/grass5.0.2/src.garden/grass.postgresql'
GISGEN failure at STEP: src.garden/grass.postgredo g3d /SG4d not offer the
possibilty to study a 4th dimension (temp) within a 3d spatial
environment?sql
do you have any indication what goes wrong??
I also have problems while attaching pgaccess to the postgresSQL database I
don't know if this is a comparable problem with shared libraries - I'll
request the postgreSQL-list
version 98.7:
nico at laptop:/usr/local/pgaccess> ./pgaccess
Error in startup script: couldn't load file "libpgtcl.so": libpgtcl.so:
cannot open shared object file: No such file or directory
while executing
"load libpgtcl[info sharedlibextension]"
(procedure "main" line 3)
invoked from within
"main $argc $argv"
(file "/usr/local/pgaccess/main.tcl" line 249)
version 98.8:
nico at laptop:/> pgaccess
Parsing the command line parameters:
Loading the cmdline package... FAILED
Error: can't find package cmdline
Please install the tcllib package
(http:://www.sourceforge.net/projects/tcllib)
Error in startup script: invalid command name "cmdline::getopt"
while executing
"cmdline::getopt argv $getopt_list opt val"
(procedure "parse_cmd_line" line 85)
invoked from within
"parse_cmd_line"
(procedure "init" line 10)
invoked from within
"init $argc $argv"
(file "/usr/X11R6/bin/pgaccess" line 736)
Additionally, I also want to use 3d voxel routines - g3d / SG3d / sg4d - and
have problems to get g3d compiled see mail "problem compiling g3d"
thanking in advance,
Nico
-----Oorspronkelijk bericht-----
Van: Markus Neteler [mailto:neteler at itc.it]
Verzonden: woensdag 23 april 2003 11:19
Aan: Nico Hardebol
Onderwerp: Re: [GRASSLIST:6105] RE: NVIZ problem
On Tue, Apr 22, 2003 at 02:42:23PM +0200, Nico Hardebol wrote:
> I'm running the newest Suse linux 8.2 on dell laptop - but afterwards
> downgraded the tcl/tk libraries to 8.3 (instead of 8.4)
which tcl/tk does Suse 8.2 deliver: 8.4.?
This is important to know as we probably have to add extra header
files to NVIZ.
Markus
