[GRASSLIST:897] Re: CELL, FCELL, DCELL type...
Massimiliano Cannata
massimiliano.cannata at ist.supsi.ch
Mon Aug 4 06:15:36 EDT 2003
Glynn Clements wrote:
> Massimiliano Cannata wrote:
> > I'm trying write a code that use a raster to make
> > calulation....
> > so I get the raster cell value (CELL, FCELL, DCELL
> > depending on the original map) and then i have to
> > use the math.h function
> > double pow(double,double)
> > so, how do I have to cast CELL, FCELL or DCELL to
> > double?
> > It seems that
> > double x;
> > x = (double) CELL
> > doesn't work...
> It should work.
> > more, I have to really do this casting?
> ANSI C will automatically cast numeric function arguments to the
> appropriate type, so you can just pass CELL values to pow() directly.
> Glynn Clements <glynn.clements at virgin.net>
So if it is able an automatic cast...
i don't really need to develop 3 version of my calculus module as in the
"r.example" for the switch type....
i can just make one, doing someting like:
double mycalculus(double x)
and than pass CELL, DCELL or FCELL as argument?????
Thanks a lot.
Max
____________
---r.example----
____________
switch (data_type)
case CELL_TYPE:
c = ((CELL *) inrast)[col];
c = c_calc(c); /* calculate */
((CELL *) outrast)[col] = c;
break;
case FCELL_TYPE:
f = ((FCELL *) inrast)[col];
f = f_calc(f); /* calculate */
((FCELL *) outrast)[col] = f;
break;
case DCELL_TYPE:
d = ((DCELL *) inrast)[col];
d = d_calc(d); /* calculate */
((DCELL *) outrast)[col] = d;
break;
Ing. Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at ist.supsi.ch
Internet: http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030804/d8cfb6b4/attachment.html
