[GRASSLIST:923] Re: Handling millions of points in GRASS...
Sandro Klippel
sandro.klippel at talha-mar.com.br
Thu Aug 7 11:52:47 EDT 2003
I worked with approximately 4 millions points of batimetric data of
southern Brazil continental margin. For performance reasons I preferred
working with GMT tools and awk scripts. But the awk scripts was used
only for filter out bad data. 'blockmean' and 'surface' grid data in few
seconds. Then I imported to grass/nviz with 'r.in.bin' for 3d
visualization.
You can use the 'gmtselect' for spatial selections.
Sandro.
On Thu, 2003-08-07 at 06:00, Bernhard Reiter wrote:
> On Wed, Aug 06, 2003 at 09:23:56AM -0700, David Finlayson wrote:
> > I know that RDBMS support is coming soon and that (apparently) PostGIS
> > is already functional on some platforms (Linux, Cygwin?). But what is
> > the word from the trenches? I have been very happy with MySQL and would
> > rather use this if functionality is comparable to PostGres, but it would
> > be better to move now rather than wait if necessary...
> > A major task that needs to be handled is some way to select points both
> > by spatial location (polygons not boxes) and by attributes such as age,
> > survey, and platform. Currently, I have a table of soundings (x,y,z,ID)
> > and a table of headers (ID,date,platform,etc.) and I load it into
> > ArcGIS (ESRI, inc.) through ODBC where I can grid up the data into
> > rasters for further analysis. Hence, I am currently dependent on Windows.
> How to hold the data depends on your usage requirements.
> If you do many queries that could benefit from sofisticated indexes
> you should think about using PostGIS.
> Also if you need data security.
> Also check out this post comparing the upcoming geographical features
> of MySQL 4.1 and postgis:
> http://intevation.de/pipermail/freegis-list/2003-July/001449.html
> Basically MySQL
> does not offer transactional security and nice index technology.
> Radim and Sandro already pointed out that there are several
> ways to get points out of the database into GRASS.
> The more complicated approaches (like moving to PostGIS
> and optimising the indexing) only make sense if you really
> have the usage pattern for it. I agree with Radim that cleverly used
> text files might give good results.
Sandro Klippel <sandro.klippel at talha-mar.com.br>
talha-mar projetos ambientais
Conselheiro d'Avila 190
Porto Alegre,RS 91040-450
+55 (51) 3344-7451
w w w . t a l h a - m a r . c o m . b r
