[GRASSLIST:928] Re: CELL Maps to proper UTM Coordinates
Markus Neteler neteler at itc.it
Fri Aug 8 03:24:13 EDT 2003
On Fri, Aug 08, 2003 at 05:15:16AM +0100, Kurt Springs wrote:
> Hi Folks
> I was wondering how to get a scanned cell map so that its edges are in the
> proper UTM coordinates so that it can be traced in v.digit, and later site
> data added using the National grid.
In short:
1) Import the map into a XY location
2) i.group, i.target to the UTM location
3) Then run i.points to reference the 4 corners (or anything nearby). You
need to know the coordinates of these 4 points which are then entered into
the terminal window of i.points.
Check the error with "Analyse" menu entry
4) Then i.rectify it with 1st order into the UTM location.
   An email arrives when the job is done.
4) leave the XY location, switch to the UTM location and verify
again with other GIS data.
Hope this helps
 Markus
