[GRASSLIST:939]
Cannata, Massimiliano massimiliano.cannata at supsi.ch
Mon Aug 11 10:08:08 EDT 2003
Hi all,
I try to use s.vol.rst to interpolate some temperature
values but i get some error message....
I know I have few points but i guess that's not the
problem.....
I get CSV experimantal code and install the g3d
components.
So my operation was:
1--> g3.createwind
2--> g3.region and get this region:
CURRENT REGION: N=170012.5  S= 73987.5  RES=200.05208333
   ROWS=480
                 E=742512.5  W=672487.5  RES=200.07142857
   COLS=350
                 T=    3500  B=     100  RES=         200
 DEPTHS=17
PROJECTION: 99 (Swiss. Obl. Mercator)
ZONE:       0
3-->s.vol.rst input=temperatura at laura cellinp=ti25dem
npmin=3 segmax=400 cellout=temp3d elev=temp3dvol
but i get this rensponse:
Percent complete: Error in COGRR!
ERROR: Interp_call failed!
Can be some NULL value in the cellinp raster file the
problem?
Can be too few points the problem?
Have you any idea???
Has anybody else used with succes thi s.vol.rst command?
Thanks you all.
Eng. Massimiliano Cannata
Phd student
www.supsi.ch
Phd student
www.supsi.ch
