[GRASSLIST:957] Re: live GRASS/GPS interface
Buchan Milne
bgmilne at cae.co.za
Fri Aug 15 04:46:22 EDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hamish wrote:
> I've been thinking about how to do a real-time GRASS/GPS interface.
> General idea is to have a GPS feeding NMEA statements into the laptop's
> serial port, and have a program running in the background which parses
> the statement, feeds it through PROJ, and appends the result into a
> site_lists/gps_track file, as well as replacing the single point in a
> site_lists/latest_postion sites file. Lat-Lon, Time, COG, SOG, other GPS
> messages would be written to the site's comments. (or even run r.what
> for that position and use that in the comment string)
> e.g.:
> d.rast topo
> d.vect contours
> d.sites gps_track color=red size=1
> d.sites latest_position color=red size=3
> d.site.labels latest_position attr=...
> then, d.redraw or d.pan should update the track whenever I update the
> monitor.
> I suppose you could also have a background process which runs:
> g.region sites=latest_postion
> d.redraw
> every few minutes if you wanted. It could even do a little math so it
> only redraws when latest_postion is outside WIND ...
> I suppose a 5.1-style GUI could be written to control all this..
> Not very clean, but I think it should work.
> I've already written the NMEA parser, output to the sites format is
> trivial, but I'm not sure about how to go about the serial port daemon
> (although I am pretty familiar with RS232 i/o).
I have been doing some similar stuff (not directly to grass, I need some
ohter processing first), and found it convenient to make a gpsd client.
This allows the use of a remote GPS, or a local GPS, and allows you to
forget about managing the serial port, and also allows multiple programs
to access the data.
Regards,
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/PJ3drJK6UGDSBKcRAtXfAJ9dMaaD8ES69oKnqMAG+2TqW9/zBwCeIDJA
9KfkStk6kVX5Bl6zsJVQbk0=
=N8Ho
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info at cae.co.za for a copy.
