[GRASSLIST:1000] Re: importing tif file - Segmentation fault (core
 dumped)
    Don Harter
    harter_d at bellsouth.net
    Fri Aug 22 18:16:15 EDT 2003
I got the r.in.gdal to work in importing SDTS USGS 7.5" DEM data file.  It appears
to have been just a configuration issue.  I used the input file to create a
region, then I exited grass, restarted it (that is one trick that I found in one of the tutorials) and ran r.support.  Previously
r.in.gdal segmetation faulted when my PROJ_INFO and PROJ_UNITS were not set
which is caused by incomplete location information.
I am not sure what was causing the memory leaks.  I think it was perhaps because I was debugging grass in a local directory
 and there was already another version that had been installed system wide.
stef wrote:
>Dear Don,
>You either have a memory leak.. or another memory
>problem..
>good luck,
>stef
>--- Don Harter <harter_d at bellsouth.net> wrote:
>>Florent AUBIN wrote:
>>>Hello
>>>I'm trying to import a tif file with r.in.gdal.
>>>It seems that everything goes right but when it
>>begins
>>>to import I have the following message:
>>>Segmentation fault (core dumped)
>>>Does anyone know how to solve it?
>>>Thank you very much!
>>>  Florent
>>___________________________________________________________
>>>Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et
>>en français !
>>>Yahoo! Mail : http://fr.mail.yahoo.com
>>I have had a similar problem with SDTS files and
>>r.in.gdal.  I submitted
>>a bug report and did some troubleshooting.
>>It seems that there is a memory leak that causes
>>r.in.gdal to overwrite
>>itself and cause a segmentation fault.
>>I had done some debugging and isolated it to a
>>certain file/subroutine.
>>The source code is probably not being intepreted the
>>same on different C
>>platforms.  On one it works and on redhat 7.3/9.0 it
>>gives a
>>segmentation fault.
>>Here is the link to the bug report:
>http://bugzilla.remotesensing.org/show_bug.cgi?id=359
>Do you Yahoo!?
>Yahoo! SiteBuilder - Free, easy-to-use web site design software
>http://sitebuilder.yahoo.com
