[GRASSLIST:1080] hung processes
Don Harter
harter_d at bellsouth.net
Sun Aug 31 19:25:42 EDT 2003
Sometimes when I run zoom in on a map set or query a mapset with a mouse
the process "hangs".
I know this because I will try to run a command and the output window
does not pop up.
If I run a ps ax command I can see a process running for a command.
When I kill that process I can run the command that I had wanted to and
a window pops up
with the following message:
invalid command ".d_what_rastbutton7"
while executing
$path configure -text Run -fg blue -activefourground blue
(procedure reader line 11)
invoked from within
"reader file5 .d_what_rastbutton7 (d.what.rast map=only) -1"
What is wrong?
