[GRASSLIST:1929] Re: pie/bar chart of vect variables in 5.0.x
Martin Wegmann
mailinglist2_wegmann at web.de
Mon Dec 1 15:39:49 EST 2003
On Monday 01 December 2003 21:20, Paul Kelly wrote:
> On Mon, 1 Dec 2003, Martin Wegmann wrote:
> > Error in startup script: ps.map: error while loading shared libraries:
> > libproj.so.0: cannot open shared object file: No such file or directory
> > while executing
> > "exec ps.map -p"
> > (procedure "DmPrint::init" line 14)
> > invoked from within
> > "DmPrint::init"
> > (procedure "main" line 30)
> > invoked from within
> > "main $argc $argv"
> > (file "/usr/local/grass57-29_11_2003/etc/dm/d.m.tcl" line 785)
> Make sure your libproj.so.0 is installed in a directory your system
> searches for shared libraries in, e.g. add this directory to your
> LD_LIBRARY_PATH environment variable or on Linux to the list in
> /etc/ld.so.conf and run ldconfig.
wow! that looks good - nice map display handling.
the problem with libproj.so.0 worked pretty straight forward in debian
testing/unstable. installing proj and running grass57, nothing else. thanks
for the info.
cheers Martin
