[GRASSLIST:1954] Re: topograpic analysis using GRASS and R
Hamish
hamish_nospam at yahoo.com
Wed Dec 3 19:32:06 EST 2003
> I'm trying to see the realtion beetwen aspect and slope for a given
> area using R. I have in mind a graph with different scales on the
> axis. For instance, I could have the scales for aspect in the bottom
> (0-360 deg) and left (density) axis , and for slope in the top (0-65
> deg) and right (density) axis. But I don't know how to do this.
> already searched the web, but without luck. Does anyone already made
> something like this?
be careful with GRASS's aspect, it isn't compass direction (0 deg = North).
use this script to make the conversion if wanted.
#!/bin/sh
# r.cat2compass.sh by Hamish Bowman 11 April 2003
if [ -z $GISBASE ] ; then
echo "You have to be in GRASS to use this."
exit
fi
if [ -z "$1" ]; then
echo "USAGE: r.cat2compass.sh AspectRaster"
echo " Make a cartesian angled aspect raster into a compass angled raster"
echo " newfile is oldfile_compass. (ccw from east -> cw from north)"
exit
else
INPUT_MAP=$1
r.mapcalc "$INPUT_MAP"_compass="if(isnull($INPUT_MAP),null(), \
if(($INPUT_MAP < 90), 90-$INPUT_MAP, 360+90-$INPUT_MAP))"
##### lighting for SOUTHERN HEMISPHERE (northern sun) #####
r.colors "$INPUT_MAP"_compass color=rules << EOF
0 white
180 black
360 white
EOF
fi
