[GRASSLIST:1967] Re: no rule to make shapefil.h
Markus Neteler
neteler at itc.it
Sat Dec 6 07:40:25 EST 2003
On Fri, Dec 05, 2003 at 10:58:37AM -0500, Christopher Fonnesbeck wrote:
> After updating grass57 and 53 source from CVS to fix the DYLIB problem
> on OSX, I get the following:
> gcc -L/usr/local/lib -L/sw/lib
> -L/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/
> lib -dynamiclib -Wl,-flat_namespace,-U,_cuserid -undefined suppress
> lib \
> OBJ.powerpc-apple-darwin7.0.0/edit_cats.o
> OBJ.powerpc-apple-darwin7.0.0/edit_cellhd.o
> OBJ.powerpc-apple-darwin7.0.0/edit_hist.o -lgrass_gis -lgrass_datetime
> -lintl -lgrass_vask -o
> lib/libgrass_edit.dylib
> external
> bwidget
> if [ ! -d
> bwidget ]; then mkdir
> bwidget; fi
> tar cf - images/* lang/* *.txt *.tcl README.grass | (cd
> bwidget; tar xf -)
> shapelib
> make[3]: *** No rule to make target `shapefil.h', needed by
> `/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/
> include/shapefil.h'. Stop.
> make[2]: *** [subdirs] Error 1
> make[1]: *** [subdirs] Error 1
> make: *** [default] Error 1
> Seen this before?
Did you run
make mixclean
during you update procedure? The complete procedure is explained
in the INSTALL file of 5.7:
UPDATE OF 5.7.x
Assuming that you want to update your current installation from
CVS, you have to perform a couple of steps. In general:
- clean the links to 5.3.x
- update from 5.3.x CVS HEAD (the 5.3.x code)
- update from 5.7.x CVS (the 5.7.x code)
- recreate the links to 5.3.x (make mix)
- configure, compile
In detail:
cd /where/your/grass530/lives/
cvs update -dP
cd /where/your/grass57/lives/
make mixclean
cvs update -dP
make mix
configure ...
make
Hope this helps,
Markus
