[GRASSLIST:1999] Re: error with gdal
Markus Neteler
neteler at itc.it
Tue Dec 9 05:40:26 EST 2003
On Mon, Dec 08, 2003 at 11:54:10AM +0100, hamdi ines wrote:
> Hello,
> I m download gdal-cvs-031203 to read gml file in
> grass57,but when i execute the command make (after
> ./configure) the result is:
> >make[2]: Entre dans le répertoire
> `/home/versionfinaledocgrass57/versionsforopenevfw-gdal/gdal-cvs-031203/frmts/png'
> make[2]: Rien à faire pour `install-obj'.
> make[2]: Quitte le répertoire
> make -C grass install-obj
> `/home/versionfinaledocgrass57/versionsforopenevfw-gdal/gdal-cvs-031203/frmts/grass'
> /bin/sh ../../libtool --mode=compile g++ -I../../port
> -I../../gcore -I../../ogr -Wall -O2 -c -o
> ../o/grassdataset.o grassdataset.cpp
> g++ -I../../port -I../../gcore -I../../ogr -Wall -O2
> -c grassdataset.cpp -fPIC -DPIC -o
> ../o/.libs/grassdataset.o
> grassdataset.cpp: In static member function `static
> GDALDataset*
> GRASSDataset::Open(GDALOpenInfo*)':
> grassdataset.cpp:513: invalid conversion from `int
> (*)(...)' to `int (*)()'
> make[2]: *** [../o/grassdataset.o] Erreur 1
This is a known GDAL problem:
http://bugzilla.remotesensing.org/show_bug.cgi?id=408
(I have the same problem)
Maybe you post a message into that bug thread.
Markus
