[GRASSLIST:2023] Re: conversion of sites to 5.7 from 5.0
Markus Neteler neteler at itc.it
Thu Dec 11 03:25:51 EST 2003
On Wed, Dec 10, 2003 at 05:53:08PM -0500, Christopher Fonnesbeck wrote:
> I am trying to convert some sites over to version 5.7 vector format,
> but am unable to use v.convert. I get the following:
> GRASS 5.7.-cvs:~/Research/INLAS/GIS > v.convert input=bridges
> output=bridges
> ERROR: Input vector was not found.
> Yet, when I list the sites, I get:
Did you run
  g.list vect
or
  g.list oldvect
Note that your 'bridges' map must be present in the old vector format.
Since you refer to 'sites', v.in.sites might be the right module.
v.in.sites help
Description:
 Converts a GRASS site_lists file into a vector file.
Cheers
 Markus
> site list files available in mapset PERMANENT:
> bridges         hatchery        recreation
> What am I missing?
> Thanks,
> C.
> Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
> Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
Markus Neteler     <neteler at itc.it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
