[GRASSLIST:2092] Re: GRASS and r.reclass in a batch errors
javier garcia - CEBAS rn001 at cebas.csic.es
Thu Dec 18 10:21:27 EST 2003
Hi all,
I'm sorry, Hamish. This still does an error. I even have commented nearly
everything to find out the source of the error. But even doing it for a
single map  gives an error:
#!/bin/bash
#  reclass script
# i=1
# while [ $i -le 25 ] ; do
r.reclass input=imagen1end output=imarec1end << EOF
       253 = 192
       252 = 96
       251 = 48
       250 = 24
       249 = 12
       221 = 8
       193 = 7
       165 = 6
       133 = 4
       102 = 3
       70 = 2
       39 = 1
       * = NULL
       end
EOF
# i=$(($i + 1))
# done
# if you want the maps to be 01,02,03,..,09,10,11 add this line:
# MAP=`echo $i | awk '{printf "%02i", $1}'`
# echo $MAP
ERROR:        253 = 192
       - invalid reclass rule
Perhaps a modification in the format for reclassification rules?
Javier
El Jue 18 Dic 2003 13:17, escribió:
> On Thu, 18 Dec 2003 10:12:51 +0100
> "javier garcia - CEBAS" <rn001 at cebas.csic.es> wrote:
> > Hi Hamish,
> > thanks a lot for the attached.
> > Is it possible that the script has an error?
> > I've run it and I receive a lot of messages like:
> > ./reclass_scrip.sh:  : command not found
> > Best regards,
> > Javier
> Yes, very likely there's an error. I didn't actually test the script.
> try replacing
>    i=`expr $i + 1`
> with
>    i=$(($i + 1))
> and see if that works.
> Hamish
> > > > The problem is to pass values of reclassification rules
> > > > to r.reclass. I've tried:
> > > > But this doesn't work. I think that this could be also with a bash
> > > > script, but I don't know anything about bash.
> > > It is actually pretty clean with Bash, try the attached.
> >  #!/bin/bash
> >  #  reclass script
> >  i=1
> >      r.reclass input=imagen$i output=imarec$i << EOF
> >         253 = 192
> >         252 = 96
> >         251 = 48
> >         250 = 24
> >         249 = 12
> >         221 = 8
> >         193 = 7
> >         165 = 6
> >         133 = 4
> >         102 = 3
> >         70 = 2
> >         39 = 1
> >         * = NULL
> >         end
> >  EOF
> >      i=`expr $i + 1`
> >  done
