[GRASSLIST:2098] LD_LIBRARY_PATH error with gdal
Thomas Adams
Thomas.Adams at noaa.gov
Fri Dec 19 14:59:47 EST 2003
I'm trying to use r.in.gdal under redhat Linux, GRASS 5.0.2 and I get
the following error:
GBBridgeInitialize() failed to find an suitable GDAL .DLL/.so file.
The following filenames were searched for:
o libgdal.1.1.so
o gdal.1.0.so
o gdal.so.1.0
o libgdal.so.1
The following locations were searched:
o /awips/grass/lib
o System default locations.
System default locations may be influenced by:
LD_LIBRARY_PATH =
/awips/grass/lib:/usr/local/motif/lib:/opt/informix/lib/esql:\
/opt/informix/lib:/awips/hydroapps/lx/gcc_shlibs
ERROR: Unable to initialize GDAL bridge (check libgdal
installation/LD_LIBRARY_PATH variable).
the gdal library, libgdal.1.1.so, is installed in $GISBASE/lib, which is
/awips/grass/lib.
Any suggestions? I installed the binary release. Otherwise, all other
commands that I have used run fine.
Regards,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20031219/17483a6b/attachment.html
