I have a vector map in ESRI/SHAPE and DXF format too, with labels. I imported these with v.in.dxf and v.in.shape. If i import dxf, labels invisible, only "outlines" visible on the right place. If i import ESRI/SHAPE format, d.vect.labels put them on the right places, but not rotated. How can i rotate a label with specified angle? thanks
