[GRASSLIST:5455] Re: problem in g.select.pg
Ingo Wichmann
wichmann at uni-wuppertal.de
Mon Feb 3 12:31:19 EST 2003
temiz schrieb:
> when I try to connect postgreSQL server this message appears:
> /"g.select.pg: error while loading shared libraries: libpq.so: cannot
> open shared object file: No such file or directory."
> /How can I correct it ?
Sounds like there is a problem with your installation. Did you install
from a binary or from source? What OS are you using?
On suse-linux the missing file "libpq.so" is provided by the
postgresql-libs rpm. So you would correct it by installing postgresql-libs.
Ingo
