Hi again If I produce a level 1 map by either v.rm.dangles or v.support input=<abc> option=build err=map, that map will NOT display with d.vect until I run v.support on it. Is that normal? I thought I should be able to display these without v.support. (Grass 5.0.0, sun, solaris 2.7) John
