[GRASSLIST:5496] RE:  Can't resize monitor.
    H. Bowman
    ihatejunkyabastards at yahoo.com
    Fri Feb  7 00:10:02 EST 2003
Matt Doggett wrote:
> Problem:  Using Grass5.0, we cannot resize the Xwindow monitor created
> using d.mon.
> 2.    Several people have reported a "d.resize" command.
or more generally d.monsize:   [broken in 5.0.0, fixed in CVS]
USAGE: d.monsize <monitor_width> <monitor_height> <monitor_name>
It lets you specify a specific monitor too, otherwise seems to be
redunant with d.resize.
Glynn Clements wrote:
> The initial size of a monitor is determined by the GRASS_WIDTH and
> GRASS_HEIGHT environment variables, e.g.
>       GRASS_WIDTH=512
>       export GRASS_WIDTH
>       GRASS_HEIGHT=384
>       export GRASS_HEIGHT
which is right,
while John Gillette wrote:
> In html man pages under Drivers -> XDRIVER :
>  XDRIVER_WIDTH=xxx
>  XDRIVER_HEIGHT=yyy
>  XDRIVER_LEFT
>  XDRIVER_TOP
which are now wrong.
John again:
> If you use the TCLTK menus:
> Config (on the very left hand side) ->Options ->Display dimensions
This seems to be broken in 5.0.0 as well as CVS.
(/src/tcltkgrass/main/gui.tcl)
so off I go to file two more bugs..
Hamish
