[GRASSLIST:5507] Re: d.erase
    Glynn Clements
    glynn.clements at virgin.net
    Fri Feb  7 20:12:24 EST 2003
Aldo Clerici wrote:
> with version 5.0 it seems no more necessary to run d.erase after a region
> change or a monitor resizing. Is this correct?
You need to run d.erase after a region change, but not after resizing
the monitor.
Some display (d.*) programs read the region from the monitor, while
others read it from the WIND file (via G_get_window()). So, if you
omit the d.erase, some programs will work while others won't.
Glynn Clements <glynn.clements at virgin.net>
