[GRASSLIST:5513] Re: v.digit and v.cutter
    Jason Morgan
    jwm-grass at sentinelchicken.net
    Sun Feb  9 10:12:12 EST 2003
OK, I have managed to use v.digit to draw the proper boundaries around
my area, but I have run into another problem. My intent was to use the
new vector file I created to cut the old vector file down to size. Well,
it isn't working. The use of v.cutter seems to work - at least it does
something - but when I try to display the new layer - nothing. Any
suggestions?
Jason
On Fri, Feb 07, 2003 at 03:01:57PM -0500, Jason Morgan wrote:
> I have a map of parcel data in vector form and would like to restrict
> my queries to a certain area. For example, in Arc View, I was able to
> draw an outline around my area of interest and then extract information
> for only those parcels contained in that area. Is there similar
> functionality in GRASS? I don't have the money to buy ArcView, so that
> isn't an option, but I really need to be able to do this.
> I would really appreciate it if someone could point me in the right
> direction.
> Thanks,
> Jason
