[GRASSLIST:5537] Problem compiling Grass 5.1 last version (08/02/2003)
maurosw at jumpy.it
maurosw at jumpy.it
Thu Feb 13 03:06:24 EST 2003
Hi to all,
I have a problem trying to compile last version of Grass51
(08/02/2003)...
I use this configure parameters:
CFLAGS="-g -Wall" ./configure
--with-grass50=/home/rpms/GRASS/Sept2002/grass50_exp_2003_02_08
--with-gd-includes=/home/rpms/gd-1.8.4
--with-gd-libs=/home/rpms/gd-1.8.4
--with-postgres-includes=/usr/local/pgsql/include/
--with-opengl-includes=/usr/X11R6/include/
--with-opengl-libs=/usr/X11R6/lib --with-dbm
--with-dbm-includes=/home/rpms/gdbm-1.8.0 --with-dbm-libs=/usr/local/lib
--prefix=/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu
--with-gdal
and there is no problem:
GRASS is now configured for i686-pc-linux-gnu
Source directory: /home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08
Build directory: /home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08
Installation directory: /home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/grass5
C compiler: gcc -g -Wall
FORTRAN compiler:
NVIZ: yes
X11 support: yes
DBM support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: yes
ODBC support: yes
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
but I have this error:
gcc -g -Wall -Wall -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include
-I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/include
-I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/include
-I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include
-I/usr/local/pgsql/include/ -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include
-o OBJ.i686-pc-linux-gnu/open_ogr.o -c open_ogr.c
cc1: warning: changing search order for system directory "/usr/local/include"
cc1: warning: as it has already been specified as a non-system directory
cc1: warning: changing search order for system directory "/usr/include"
open_ogr.c: In function `V1_open_old_ogr':
open_ogr.c:37: structure has no member named `ogr'
open_ogr.c:44: structure has no member named `ogr'
open_ogr.c: At top level:
/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include/gis.h:36: warning:
`GRASS_copyright' defined but not used
make[3]: *** [OBJ.i686-pc-linux-gnu/open_ogr.o] Error 1
make[3]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector/Vlib'
make[2]: *** [subdirs] Error 1
make[2]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib'
make: *** [default] Error 1
I think there is a problem with #define HAVE_OGR...
Could someone help me?
Thank you
Mauro
________________________________________
Hai bisogno di una pausa? Vieni a giocare su Jumpy! http://giochi.jumpy.it
