[GRASSLIST:5540] Command-line invocation
Michael Ash
mash at econs.umass.edu
Thu Feb 13 13:23:19 EST 2003
I would like to run v.support on many vector maps across mapsets and want to use a shellscript to manage the process.
With GISDBASE, LOCATION_NAME, MAPSET, etc., properly defined, is it possible to invoke GRASS with either a single grass command or the name of a grass shellscript, thus:
export MAPSET=angola
% grass5 - -text <grass command or grass shellscript to run v.support on several vector maps>
export MAPSET=botswana
export MAPSET=burundi
etc., etc.,
I am open to other suggestions if there is a better way. (I have the countries in separate mapsets because the vector maps have the same generic name for each country (e.g., "airports").
Michael Ash, Assistant Professor
Of Economics and Public Policy
Department of Economics and CPPA
University of Massachusetts
Amherst, MA 01003
Tel 413-545-6329 Fax 413-545-2921
Email mash at econs.umass.edu
http://people.umass.edu/maash
